I need advice
Old Nov 8, 2004 | 04:57 AM
Ÿêõ's Avatar
I need advice
Installing the following on an Evo 7 engine (yes it does plug into the JDM E7 harness.)
ACCURATE RalliArt ECU specifications needed for the following:
RalliArt Sport (For Rally) ECU RA 420996R1 used for the Evo 6
Specifications & ACCURATE Info (& links) needed -
... RalliArt recommended ENGINE specs (Cams / Fuel / Turbo / Exhaust etc)
... New BHP / Torque with stock engine. (& with RalliArt engine upgrade above)
... New RPM limit.
... New Fuel-cut limit (if any).
... New Boost limit (peak & normal) (Is new MAX really 1.55 bar / 22.4 psi?)
... Any info on new Fuel Map, new Milage etc :?:
Other relevant suggestions... :?:
Old Nov 9, 2004 | 06:05 AM
Ÿêõ's Avatar
No one?
Old Nov 15, 2004 | 07:33 AM
Ÿêõ's Avatar
Old Nov 19, 2004 | 05:19 AM
Ÿêõ's Avatar
Thanks
Old Nov 19, 2004 | 07:12 AM
EVOwhat's Avatar
I would post this on http://www.lancerregister.com/ ...you may have better responses...
Good Luck!
