Will the evo 8 clutch,pressure plate and flywheel work on the evo 7?
Old Nov 8, 2004 | 07:52 PM
11secEVO7's Avatar
Thanks in advance..
Looking to buy the ACT 6puck and fidanza flywheel but all I see are applications for the evo 8....
Old Nov 8, 2004 | 08:21 PM
Crazy4Cars's Avatar
Originally Posted by 11secEVO7
Thanks in advance..
No, it will not work, the evo8 plate is 5mm higher where the T/O bearing is compared to the 7, I did that mistake and found out afterwards.
Old Nov 9, 2004 | 06:07 PM
11secEVO7's Avatar
Are you sure about this?
I had the HKS GDMAX for the evo 7 on my car.
but when it went through, I bought the re-build kit for the evo 8 HKS GD MAX and it worked..
Old Nov 9, 2004 | 06:09 PM
Crazy4Cars's Avatar
Bro, what I told you was for single plates, twins are all the same part # from 4-8
Old Nov 9, 2004 | 07:41 PM
94AWDcoupe's Avatar
The evo4 tranny is identical to an evo8 tranny. I have both in the garage here. The evo4-7 stock clutches are 5mm smaller in diameter. If you are buying a Flywheel for an evo8 at the same time it most certainly will work.
Old Nov 10, 2004 | 04:47 AM
11secEVO7's Avatar
ok thanks man...that's exactly what i wanted to know.
cheers!!
