Oil Pump Failure
Old Nov 9, 2004 | 08:40 AM
bryans2k's Avatar
Oil Pump Failure
I recently had an oil pump failure due to what I believe was the front balance shaft. Basically what happened was the oil pump timing belt shaft moved so much that it chewed up the oil pump case housing walls when I experienced wheel hop while taking off (also broke my tranny). I believe it was due to the front balance shaft moving in ways that are un-usual. So here is my warning to evo owners who drag race. Beware of wheel hop as it might kill your oil pump/engine. I later replaced it and removed the balance shafts.
here is the balance shaft thread:
https://www.evolutionm.net/forums/sh....php?p=1376677
bryan
