afc2 install with settings?
Old Nov 10, 2004 | 05:36 AM
ebbeast2005's Avatar
Ok, Yes i didnt really do a search on this but if some1 has a little time that would be awsome if you could help me out. Bascally i want to install it. Does any 1 have a dyi on it. Can some1 run my threw the settings i need to be at. Running turbo-back 3 in w/ test pipe, i/c pipe, intake, greddy type s vta, 21 psi. Is it hard? Im pretty smart with wiring **** up as long as i know what needs to be done. Thanks
Old Nov 10, 2004 | 05:49 AM
o3evo8's Avatar
Veteran: Air Force
check out vivdracing.com under VRSM in the tech section they have basic setting in the tuning section, also thy have the a ECu pin out for the ECU this is in install tips section. Also evomoto.com has the ECU pin out on there tech page. I used Apexi's website to find out which wires i needed to splice into.
