hessitation at 6000rpm and up
Old Nov 19, 2004 | 07:23 AM
DSMotorsport's Avatar
Did you change the plugs yet?
Old Nov 19, 2004 | 07:33 AM
gomez's Avatar
thanks for the info dc motorsports and all who chimed in. i will change the plugs this saturday and will let you know the results.
Old Nov 20, 2004 | 03:41 PM
LANEVOLUTION8's Avatar
Ture But Not Enough To Case This Effect ,and The Plugs Would Look Different From The Cooent Seeping By The Head Gasket. Just Take A Look Pull A Plug And Put That Cylinder On Tdc And Shine A Flash Light Down The Pluge Hole. If The Cylinder Looks Clean With No Carbon Then It's A Headgasket Leak. Remember No Carbon, Danger !
Old Nov 20, 2004 | 04:28 PM
simevo's Avatar
Problem is the P3. Works don't have P3, just a P2.
Old Nov 26, 2004 | 09:35 AM
gomez's Avatar
ok p2 my bad! anyway i changed the plugs to denso iw24 and what do you know problem fixed! also feels like engine pulls alot smoother know, had tach at 7800 rpm's with no hesitation. thank you to all who gave me advise.
