CAM question
CAM question
Is there anytime where a 264in\272ex would be better then 272s on both sides? Has anyone dynoed from one combo to the next? Trying deceide which way to go. Also wondering which would be better for autocrossing too.
For autocrossing I would prob go with 264's... On both.. They would give you better midrange torque.. As the 272's give you better top end power.. Especially for the higher gears.. Good luck...
allot of purchaser of the 272's all around complain of idle problems....tuning is the key; more radical cams simply dont idle like stock (unless the Evolution is some magical car that reacts perfect to all mods
) Take a look at the Works custom grind....its worth considering
