Help!!! How do i fix this.
Old Nov 24, 2004 | 01:42 PM
Mach 8's Avatar
Smile Help!!! How do i fix this.
Alright,
i have a Catless TBE and im now getting a CEL for the 2nd o2 sensor. what can i do to fix this.
Thanks,
Jay
Old Nov 24, 2004 | 01:44 PM
siantjab's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=98573
Works like a charm!
Old Nov 24, 2004 | 01:47 PM
UFO's Avatar
UFO
You can try one of two things. Cheapest way is the manual fix which involves a couple of spark plug anti-foul adapters and a 1/2" drill bit. It will cost you a few bucks and seems to work fine. However, it will extend your O2 sensor away from the catback and if you run a Perrin catback, like me, then it will hit the floor so it won't work for everyone. The other option is to install some sort of MIL eliminator in the wiring for the O2 sensor and this will run you anywhere up to $100 and involves removing the passenger seat.
Both methods have been covered extensively on here and a quick search will net you some more info.
