The project started
Old Nov 30, 2004 | 06:13 PM
LSs1Power's Avatar
The project started
The EVO is at the shop now and Extreme Motorsport just started with the baseline runs. The car is getting lower forged 8.1 C/R pistons, rods, cams 272/272, dual springs (8600RPM redline), cam gears, AEM EMS, AEM ignition, Clutch master clutch, big FMIC, Garrett GT35R .68 A/R, 880cc injectors (might go 1000cc if needed), fuel pump, Alky injection, and other stuff.
The car is going to have three maps two of them can be switched with a button and the third map will have to be uploaded via PC. The first map will be pure pump gas running 20-21psi. 2nd map will run 25-26psi running pump gas and alky. The last map will be running 32-34psi running race gas which is the one that is going to be uploaded by PC. The alky injection is going to be controlled via AEM EMS NOS controllers.
Its interesting to see what the final results will be. The car should be done at the end of this year. Can't wait to see the final product.
Interesting results today.... The car baseline run were around 223whp. Anyways Shaun took the filter out and it put down 25xwhp. I didn’t know that the stock Air box was that restrictive. He is going to drop a K&N filter tomorrow just to see how much the car gain over stock. Just having fun with the car before they get it apart lol.
Old Dec 1, 2004 | 12:55 AM
memo3's Avatar
sounds great!
Keep up the good work man...
and any plans for any kind of suspension work?
Old Dec 1, 2004 | 12:57 AM
LSs1Power's Avatar
Originally Posted by memo3
sounds great!
Suspension, brakes and looks will be delt with later
Old Dec 1, 2004 | 02:27 AM
mrmefodman's Avatar
this should be one sweet ride when finished. let us know on the progress and pics if u stop by the shop.
Old Dec 1, 2004 | 08:51 AM
LSs1Power's Avatar
Sure.
