New filter and boost problem
Old Dec 10, 2004 | 02:55 PM
WishIhadaEvo's Avatar
ok well my friend has a evo with a mbc and blow off. today he had his stock box in and was running 19 psi like he should. we installed a k & N Cone filter.. the one that u just buy and it bolts up to the MAS air meter. well then as he full throttles to test it out his boost only went to 15 now so we turnd up the controller ...still now 16 so we kept goin up and up and now it still wont go over 18 and the nut inside the controller that u screw up and down for boost is like almost up and it still wont get back to 19. and i know we should be like boosting alot cuase when he had boost spike once i accidently turnd the controller wrong way and it spiked 24 so we turnd it down at its been at 19 for awhile. and im just wondering why it only goin to lik 18 and wont go any higher. and weve prob turnd the controller about 8 full turns to increase boost. and when we had the stock box about 1 turn equaled 1 lb of boost. if anyone knows what may be goin on .. please help. thanks
ryan
Old Dec 10, 2004 | 03:01 PM
04BLUBYU's Avatar
Did you reset the ecu by disconnecting the battery? If not I would try that.
Old Dec 10, 2004 | 03:09 PM
yes i unhooked the battery while working on the car with the mas meter plug and stuff we even let the car idle for about 5 mins then drove regular then tried heavy throttle. anyone else have an idea?
Old Dec 10, 2004 | 03:32 PM
use2vtec's Avatar
Did you double check and make sure you didnt mess up any of the honeycomb material inside of the MAF sensor? Also go and check all of your connections, you could just simply have a big boost leak. Go and check the connection of the MAF pipe to the turbo and then check all of your intercooler piping connections.
-Leonard
Old Dec 10, 2004 | 10:23 PM
ok i will tomarrow but we didnt really mess with any of that
jsut had to take the MAF sensor part of to get if off the box and install the new bracket.. u think he needs a reflash? i was reading on dynoflash and they where sayin one u add cams or intakes to a evo it needs to be reflashed.. and no i didnt touch the combs cause i read not to touch em. any other suggestions... 2night he got it to 19 but thats at 32 degrees out instead of like the 42 it was earlier today. thanks
ryan
Old Dec 10, 2004 | 10:31 PM
guitardave24's Avatar
Put the stocker back on and if it still holds at 19+, throw the filter in the trash.
Old Dec 10, 2004 | 10:37 PM
yea we may try taht toamrrow cause its pissn me off. cause wehre the little nut in the mbc is it should be at like 26 psi like the one time we accidently did with the stock box. we though for the turbo xs that counterclockwise was boost down but its up. he really seems to not care .. but i guess i do cause something is wrong when it wont go over 19. we may try the box back on tomarrow and it if the filter then i told him to sell it to someone and get a drop in. anyone think not being a retuned chip is the problem?
