HKS 3037s
Old Dec 20, 2004 | 01:14 PM
Motaz's Avatar
Arrow HKS 3037s
Got an amazing offer today from my tunners regarding the hks 3037s turbo kit, which include the turbo, manifoild, external wastegate, down pipe, flanges and gasgates..... has anyone used this kit before, how did feel for road use sometimes daily.... thanx
Old Dec 20, 2004 | 01:33 PM
value's Avatar
Great kit 500 Hp within reach if done right.
Old Dec 20, 2004 | 02:35 PM
Motaz's Avatar
plus i have the 264/264 jun cams and motech so maybe lets see any other views
Old Dec 20, 2004 | 02:41 PM
CAR7's Avatar
Good Turbo kit but the Manifold is prone to cracking
Old Dec 20, 2004 | 09:24 PM
Ang Wen Yan's Avatar
You need:
Custom intake system
Custom made Downpipe
AEM EMS w sd convert or HKS F Con V Pro
Fuel rail
1000cc or 780 CC inj.
Walbro
Ext.l ATL fuel tank with two Bosch fuel Pump
FPR.
HKS 272/272
Titan retianer and valve spring
Fully ported head
JUN valve guide
Ferra valve with Seat locators
HKS Kansai or HKS 1.6mm metal head gasket
ARP full engime hardware
Cutom made intercooler kit with very strong BOV
EBC or MBC
Oil catch can(For engine saftey)
Old Dec 21, 2004 | 12:27 AM
EVOVII_SWE's Avatar
And why would he need these things:
Fuel rail
HKS 272/272
Fully ported head
JUN valve guide
EBC or MBC
Why the AEM EMS and the HKS cams when he already got JUN cams and Motec ECU??? And stock fuel rail will work fine with those injectors. Stock head gasket will work fine. One Walbro in tank pump will work fine. Stock head will work fine. Stock Valves and guides will work fine. Stock intercooler will work fine. And why on earth an EBC or MBC when his Motec is perfectly capable of controlling boost and also provides safety features to reduce boost at certain criteria’s? And finally would you like to explain what kind of engine safety the oil catch tank would provide?
I really don’t see the point in telling somebody that he needs all these things when he really doesn’t? I won’t argue that a ported head and a larger intercooler would improve performance but they are hardly mandatory to install a 3037?
Old Dec 21, 2004 | 04:26 AM
Motaz's Avatar
i have on the car now,
walbro 225lph
1.5 hks head gasget,
264/264 jun cam and cam gears,
trust big intercooler
buscher racing upper intercooler pipe,
buscher racing turbo pipe,
hks oil cooler upgrade,
cusco oil catch tank,
motech
i dont think i will need to do any further mods apart from replacing the turbo pipe to one that fits onto the turbo, and a new hks downpipe, since my flange is for the stock turbo.
Old Dec 21, 2004 | 04:40 AM
Az3ar's Avatar
walbro 225lph
motech
you do not need all the things that this guy said above. You need custom made DP, 750~ injectors and good tuner.
PM if you have questions
Old Dec 21, 2004 | 05:34 AM
GTVEVO's Avatar
Exactly correct, if you do install the HKS kit be sure to always be aware of this becuase it can turn into a dangerous situation very quickly. HKS makes great stuff, some alittle over priced in my opinion but I don't see why they don't pay more attention to the mainifold build quality. Just somthing to be aware of.
Old Dec 21, 2004 | 12:54 PM
turboevoct9's Avatar
what does the hks 3037 kit put out on 91 pump gas on a dyno?
Old Dec 22, 2004 | 03:21 PM
memo3's Avatar
Tuning is the key in order to make some power. If you have the bes kit in the world, without good tuning, you simply won't be able to make some good power.
So #s will depend on the tuning and how much boost you are running of course.. that won't be more than 20-21 on 91 i believe.
As for the injectors, you would need at least 660s as your duty cycle will max when you reach around 340-350whp on pump...
In my opinion, HKS makes good stuff however some people were having problems with their manifold (cracking) and also you will need to come up with a downpipe... so keep those in mind.
Old Dec 22, 2004 | 04:10 PM
mndeerslayer's Avatar
Dude, he's 10 years old.
Old Jul 14, 2008 | 12:38 PM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Old thread... but does anyone know if th more recent 3037 HKS kit come with a better designed exhaust manifold
Old Jul 16, 2008 | 12:24 AM
dxbtune's Avatar
ok nevermind mine has a support bracket... stops the cracking... time will tell
Old Jul 16, 2008 | 11:28 AM
M3EvoBR's Avatar
I have this set up, with 3037 with 1.01 hot side.
No problem at all
