Need opinions on my exhaust and chassis setup
Old Dec 22, 2004 | 12:56 AM
hkfeet's Avatar
Hey all. I ordered the 2.5" hks dp, and 2.5" hfc from ultimate racing to be bolted onto my 3" hks hipower exhaust. I went with 2.5" because I wont be upgrading my turbo or have my car faster than 400hp. I also like the low end power this setup will possibly create. I would like to hear opinions on anyone owning these components, and others, on this setup. After this I will get a ecu flash done, and have ams tune the car with a super-afc II and mbc
Also, I want to get some cusco lower tie bars, both type 1 and type 2 for more rigidity and also my stock tie bar is probably looking real bad from all the rattling my B&B 3" DP did.
Im also wanting to upgrade my rear sway bar for a little oversteer. Would the cusco 23mm swaybar be best for this? Is the 18mm swaybar more for neutral handling?
Thanks
Old Dec 23, 2004 | 10:51 AM
evo_dadi's Avatar
sounds good with the power set up as i am planning on changing my exhaust set up soon also.as with the rear sway isnt the cusco adjustable already?i would go with the 23mm tho to be more rigid. have fun modding
