Sticky Throttle?
Old Jan 4, 2005 | 08:14 PM
rino's Avatar
Sticky Throttle?
Hello everyone,
I have an 04 evo 8, I noticed that my car has a sticky throttle after I floor it. What I mean is, for example today, I had my foot all the way down on the gas pedal on 4th gear and my pedal got stuck to the floor for at least 1 second. Is this normal? I don't remember this happening when I first purchased the car. I've removed the floormat to see if it's getting stuck and the throttle still gets stuck. I don't recall this problem on my car being gear specific. Any thoughts? suggestions? Thanks,
Old Jan 4, 2005 | 08:19 PM
FuelsResearch's Avatar
check the condition of the cable at the throttle body. Open and close the throttle plate manually, with engine off, and see if there is a problem there. Throttle cable could be sticking, but I have never really experienced that on my cars or any I have worked on. The throttle is not electronic so any problem would be mechanical.
Old Jan 4, 2005 | 08:23 PM
rino's Avatar
I will follow the throttle cable and see if there's anything that could be causing my problem.
FYI - I am stock, this should eliminate questions regarding mods around the intake manifold, etc.
