Upgraded exhausts and MAF readings
Old Jan 6, 2005 | 11:27 AM
AutoXer's Avatar
I've been using an AutoTap to do OBDII datalogging. I have several of the following logs containing RPM and MAF. 1 and 2 were done on the same day. 3 was done at a later date(yesterday to be exact).
1. Stock
2. Buschur cat-back /w Magnaflow
3. Buschur cat-back /w Magnaflow, Downpipe and high flow cat
I put the logs into excel and graphed them on top of one another. I made the following graphs.
RPM vs MAF
RPM vs MAF/RPM(air flow per engine revolution... sorta like boost)
The exhaust upgrades seem to greatly improve spool-up, but didn't seem to increase air flow in the upper RPM range. I can definatly feel the faster spool-up and the car seem generally faster... I was just expecting to see more air flowing.
I'll post the graphs when I get home tonight.
Thoughts?????
Old Jan 6, 2005 | 03:14 PM
Z1 Performance's Avatar
only mods to the intake side should net you MAF changes
Old Jan 6, 2005 | 05:44 PM
AutoXer's Avatar
So where do the gains from an exhaust upgrade come from if it's not more flow into the engine?
Guess: Less force needed to push the exhaust out of the cylinder?
Old Jan 6, 2005 | 05:57 PM
nabit's Avatar
New freeflowing exhaust unrestricts the flow of spent gases so that the gases get out the tailpipe easier/faster thus reducing backpressure in the exhuast system..
Easier exit /better flow = more efficent/powerful engine..
Old Jan 7, 2005 | 01:19 PM
AutoXer's Avatar
Here are the graphs. I can't believe that no one seems to be interested in this.
Attached Thumbnails Upgraded exhausts and MAF readings-maf2.gif   Upgraded exhausts and MAF readings-maf.gif
Old Jan 7, 2005 | 01:24 PM
MVEOVA's Avatar
I can appreciate the effort but I only understand speed & power, can't comprehend what makes it!!! Just buy things and install them
Old Jan 7, 2005 | 01:36 PM
DaWorstPlaya's Avatar
I appreciate the effort as well .... thanks for putting up the find .... I've always wanted to know what kind of effect just bolt-ons would do with out messing with the ECU. Did you notice any difference in spool time with just a catback?
