HKS cams and redline
well yeah, need to remove rev limiter. I mean like valve springs or that sort of thing, what do i need to safely rev to 8k. A turbo won't change the safety margin of reving that high, it will just shift your power band. thank you though, any other suggestions?
Originally Posted by GTVEVO
Honestly I don't reccomend to stock engine to be reved over 7800 rpms. I actually set my rev limiters to 7500 becuase power drops off to much, you need to shift before then anyways. It don't see it giving you any additional benifit to go up to 8k. The reason I don't recomend it is becuase the stock rod bolts are a streach to yeild style bolts so they can streach after they are seated into the rod if excessive pressure is but on the bolt. This is just my opinion so others may vary. Hope it helps.
Originally Posted by ap-evo83
i suggested a new turbo so you can have power all the way to 8krpm's. just as gtevo stated you lose power at 8k rpm's on the stocker.
Then upgrade the rod bolts?
Yes 7500 or 7600 would be fine. I set mine at 7500 and trigger my shift light at 7k so I have plenty of room.
sorry, the guy that tuned my car was pulling my chain i talked to him today and he assured me rev limiter is set at 7800. i guess i will need a little more work before she sees 8200 rmps.
chris
chris
A better fuel pump, ecu flash, head and rod bolt upgrades. With higher than stock lift and duration cams, 8000 is pushing the valve springs pretty hard . You are asking them to work their load faster and farther for doubtful power gains.
Can any of you feel a power decrease any where after the factory 7000 rpm redline? When at the track, I feel shifting at 7000rpm is cutting it short and taking it to 7400~ is better!?
