Guages
Old Jan 16, 2005 | 01:12 AM
hkfeet's Avatar
Guages
I just bought a 2 guage mount from another member here, and Im thinking of getting a 52mm defi d boost guage, and a 52mm egt guage. Im wondering if there is anything else I should monitor instead of the egt guage. I already have boost/battery/and oil temps on my stock mitsu guage panel. I need to swap the boost one out and hopefully replace it with a guage that fits.
So my 2 questions is, am I going towards the right direction with a boost guage and egt guage with my new 2 guage steering column mount.?
And also, what size are the stock mitsu guage so I can replace the boost one. If there is nothing that fits, I will probably buy a custom 3 guage panel with 52mm mounts.
Old Jan 16, 2005 | 12:29 PM
nchirico's Avatar
You will need an 02 Wideband for a/f as well. Pretty expensive stuff but very necessary, bout 400 bucks for mine.
Old Dec 2, 2006 | 03:48 PM
yesevo's Avatar
i also have mr. i need to replace with defi guages. what kinda guages should i put in there?
thinking going with oil temp boost and egt...
Old Dec 2, 2006 | 03:58 PM
Rutt's Avatar
I run a Defi display with oil temp, oil pressure, boost, fuel psi, water temp and EGT in my Honda and I will be doing the same in my EVO IV. One display for all of those sensors
Old Dec 3, 2006 | 05:43 AM
TTOPPOUZI's Avatar
You recommend this instead of Greddy electronic warning gauges??
