View Poll Results: Where is your master cylinder set at?
0%
picture 2
50.00%
picture 3
0%
picture 4
50.00%
Voters: 2. You may not vote on this poll
ACT CLUTCH OWNERS, Clutch Adjustment?
Old Jan 21, 2005 | 09:07 PM
plokivos's Avatar
Ok, where is your master cylinder located or look a like.
I'm trying to figure out how everyone got their set at.
Thanks.
1.
2.
3.
4.
That's the master cylinder adjustment. Mine is set at 4 now, but I don't know what the proper setup for the ACT. I think the factory is 1.
Thanks for your help.
Attached Thumbnails ACT CLUTCH OWNERS, Clutch Adjustment?-untitled-1.jpg   ACT CLUTCH OWNERS, Clutch Adjustment?-untitled-2.jpg   ACT CLUTCH OWNERS, Clutch Adjustment?-untitled-3.jpg   ACT CLUTCH OWNERS, Clutch Adjustment?-untitled-4.jpg
Old Jan 21, 2005 | 09:20 PM
GOKOU's Avatar
If stock is 1 then shouldn't you be at 3 for the ACT clutch? Futher push down for greater pressure.
Old Jan 21, 2005 | 09:21 PM
plokivos's Avatar
well, according some people the pedal should be like 2, but i was at 3 for a bit then went and changed it because it wasn't disengaging propertly.
it would studder when disengaging.
Old Jan 22, 2005 | 12:29 AM
Evoisdream's Avatar
hrmm would like to know gonna install mine soon
evoisdream
Old Jan 22, 2005 | 11:30 AM
SubiEvolved's Avatar
gonn have to check once the snow stops.
ERIK
Old Jan 22, 2005 | 01:59 PM
Mike W's Avatar
Shouldnt everyone's clutch be adjusted specifically so that they have the correct release no matter what clutch they have? The fact that Mitsubishi made the pedal adjustable tells you that even the stock clutch can require differing amounts of pedal travel. I doubt there is one setting for all cars with a specific clutch.
When you replace your clutch (with any clutch) you will need to make sure that you are getting full release with the pedal to the floor.
Mike W
Old Jan 22, 2005 | 02:05 PM
Bom's Evo's Avatar
how do you test that its fully disengaging?
honda-guy
Apr 9, 2007 08:11 AM
bbvc
Asian Forum
28
Dec 11, 2006 11:42 AM
vegasboy301
Oct 30, 2006 07:24 PM
vegasboy301
Jul 11, 2006 01:15 AM
vegasboy301
Jul 26, 2005 02:05 AM
