ACD vs. Cusco vs. DCCD
Is ACD the same as DCCD (which varies the locking of the center diff which changes the torque split from 65/35f "open" to 50/50 locked)? or does it do more? Would an aftermarket diff. (Cusco etc.) do a better job (better balance, less understeer) than either adjustable factory system?
Re: ACD vs. Cusco vs. DCCD
You need to have an open diff to be able to rotate the car and avoid the push. Then the problem with this is that too open center diff wouldn't be the best thing to have in the straight line.
That is the problem with the mechanical diffs and they can be tuned for one thing only and sacrifice the other side. Active diffs can do both and coupled with the steering wheel angle sensor and G sensors readings, it is hard to beat!!
Mr. AWD
You would have to spend a tremendous amount of track time tuning the Cusco LSD to get it to work as well as the ACD system and you'll barely see an advantage unless you plan to race.
As far as ACD vs DCCD, I'm sure how DCCD works other than it allows the driver to vary the split anywhere from 50F/50R to 35F/65R or somewhere around there. That split can be locked in place or the system can be placed in auto mode and vary the split while around corners, etc. I'm not sure what inputs DCCD takes in or how it executes compared with ACD. I guess we'll have to wait till it gets here to find out for sure.
Mark
Mark
I guess what I'm asking is how active is ACD (and DCCD)? MrAWD dosen't a 1way or 1.5 way center diff solve the corner entry understeer problem? I think the car would be awsome with 1 way front and center diffs. Very little understeer and maybe most importaintly... predictable. The problem with most active stuff on a consumer level (remember the active diffs on the WRC cars are FAR more advanced) is that they CAN be tricked in some situations. Simple, predictable, mechanical diffs may be the best choice for budget minded (can't afford WRC stuff!) track users. I agree it's gonna' take a little tuning but I think we can find the balance we need (turn-in, mid-corner, exit) without having to put ACD on the car
As of the DCCD, I am not familiar (yet, I am working on it tough
) with the auto option and what it does. As soon as I figure that out, I will post it somewhere.
For the track use, Cusco units have better usage, but you still run into the problem in the slow corners with a car that has a lot of power which would make it to push more than you would like!
Fedja
Originally posted by MrAWD
since the only fast way trough the turn is at the full throttle!!
Fedja
Fedja
You were right about the diffs, free on the way in tighter on the way out and you modulate throttle mid-corner too exit to control balance of the car. As long as you've done the entry correctly, the right ammount of driver induced yaw (trail brake) depending on how fast the corner is the rest is pretty easy (as long as you don't mash on the gas!)
I still think the 1 (or 1.5) ways will work maybe better than ACD/AYC.
"s own litirature only shows ACD helping free the car up on the entry (just like a 1way would) then AYC helping mid-corner on out (and no one it seams likes AYC on the track because it's weak, heavy and inconsistant). Thoughts?
That is not true (though it is popular fiction!) you can only do that with a low horsepower car on a high grip surface. On any car with moderate to high horsepower that just MAKES understeer (or in low speed corners with RWD it could be oversteer), either way slow. Bottom line: If you can "smack er" down to full throttle at any point in the corner you are going to slow
As of the understeer/oversteer statement, you are even more off. Any car can be tuned to do either of those. There are tendencies that come from the average factory cars, but that can be changed. If your car is tuned that way that full throttle in the turn makes the car to be slightly loose and brings the rear end out, than you could use all of your throttle that is in there. If the car is not tuned than you get what you where referring in the above text.
Fedja
If your car has an ability to accelerate and you are not using it, then you are not as fast as you could be! The same goes for the corner. If you are not at the full throttle, than you are not going as fast as you could. .
Fedja
Fedja
The guy who is at full throttle the most for a lap is not always the fastest, it is the guy with the highest average speed for the whole lap! Which means the highest corner speeds (balanced car) which will lead to higher straightaway speeds even if he has to be on the gas later.
Also a car that is tuned to be as loose as you suggest will be very slow on corner entry and even slower through transitions (slaloms, chicanes etc.) and have a slower lap time to show for it. In other words what you are suggesting does help you be on the gas earlier but overall you will be slower. (PM me for credentials or continue, this is good fun
)P.S. I still think the Cusco option will work!
O.K. Here we go...If your car is tuned to accept full throttle in the corner and be neutral it is not cornerng as hard as it could. Why? simple physics...load transfer dictates the on the gas the front will be light there fore they do not have as much avaliable grip as the could if the car were balanced therfore your corner speed is slower (even though you are at full throttle). Highest corner speed is all four tires(not just the rear) at optimum slip angle for as much of the corner as possible
Also, it is really not that important who has a higher speed at the end of the straightaway. The highest straightaway entry speed is so much more important. The one at the end has a lot to do with the HP and torque numbers of the car and still isn't enough to win. Just think of Lotus Elise vs. Camaro or something else that is on the same page.
In reference to the slaloms, those are not driven with the full throttle most of the time. Except when they are so open and short that it doesn't effect cars acceleration through the whole section. Most of them are driven with the relatively steady throttle, since even spacing doesn't change requirements between the second opening and the third...
On the other hand, this is where active center diff will be the most helpful on the AWD car and it would be very hard to tune mechanical diff to get the same characteristics.
I also find this interesting and unless someone else complains about too much of the whatever, we can do a few more rounds!
Later
Fedja
First of all we are about two rounds from agreeing! and this is only about driving on dry (or good grip wet) pavement
I totally agree that the throttle thing, not an on off switch. As far as the MR-2 (used to have a 91 turbo, great car ruined by severe pump cavitation
) and the M-3 and the AWD car each car has different weight distribution therefore "balanced" is a different attitude in each car, it's about getting the appropiate amount of vertical load (for and aft with the brake or gas or trailing throttle)to compensate for centrifugal force which gives you equal slip angles in all the tires (the ones that are on the ground!)
and equates with higher corner speeds. On entry you do want a little more yaw (slip angle in the rear) so you can straighten the wheel out sooner (and therefore get on the gas sooner) which brings me too...
"the sooner you get on the gas (in the corner) the faster you will go" and "exit speed is most important"
Absolutly not. Example: If I stop at the entry I can now be at full throttle through the whole corner but my lap time is obviously slower. So at some point you are balancing entry speed with the point that you will start accelerating. Too slow in and you can get on the gas sooner (but slow). Too fast in too slow at the apex and too late on the gas (slow as well) so what is the best indicator? If you study Telemetry (data acquisition) you will see that the best indicator of lap time is...Apex speed (that's the correct apex without a botched exit). That indicates that again balance through the corner determines lap time not how early you get on the gas. I repeat again the guy that gets on the gas the first in not usually the winner. A good way to understand this is to get familier with the "friction circle." Skip Barber's "Going Faster" is the best at explaing this stuff (I'm guessing you already have it but if you don't you'll love it) .
We're getting there!
Nobody said that you have to apply the full throttle in a violent way and unbalance the car. Then, I am wondering if you have ever seen and M3 or MR2 with inside front wheels 6" up in the air? Or, an AWD with the inside rear wheel up in the air? Or a lots of other car that have tendency to do so under the hard cornering? Higher number of wheel on the ground has nothing to do with higher cornering Gs.
Fedja
Fedja
) and the M-3 and the AWD car each car has different weight distribution therefore "balanced" is a different attitude in each car, it's about getting the appropiate amount of vertical load (for and aft with the brake or gas or trailing throttle)to compensate for centrifugal force which gives you equal slip angles in all the tires (the ones that are on the ground!)and equates with higher corner speeds. On entry you do want a little more yaw (slip angle in the rear) so you can straighten the wheel out sooner (and therefore get on the gas sooner) which brings me too...
If you study Telemetry (data acquisition) you will see that the best indicator of lap time is...Apex speed (that's the correct apex without a botched exit). That indicates that again balance through the corner determines lap time not how early you get on the gas. I repeat again the guy that gets on the gas the first in not usually the winner. We're getting there!
On the other hand, corner exit speed is not affected by anything else and that is the speed that you are attacking the straight that is ahead of you. The thing is that one who is able to apply the full throttle sooner (assuming it will be able to hold it all the way until the brake point at the end of the straightaway), will have higher exit speed and cover the straight quicker as well.
Almost there!!
Fedja
If you want to stay on the dry, that is fine with me, but the racing principles are still the same. You just have to be even more sensitive to the application of the driving commands!
Not exactly, on softer surfaces tires will make grip in a wider range of slip angles so a lot more yaw is ok, in the dry it would be slow
Well, if you stop at the corner entry, you will be able to go through the whole turn with a full throttle. But, if other driver doesn't stop as you did, but just slows down enough to still be able to apply full throttle through the whole corner, his exit speed is going to be much higher than yours, and repeated corner after corner, his overall time will be better then yours! So, I guess we are pretty much on the same page here!
Uh..no If you slow down enough to "go through the turn with a full throttle" you would be passed by 10 cars at the entry to any corner that required braking (on a road course). Remember "if you can apply full throttle in a corner you are cornering too slow!" You have overslowed just so you can get on the gas sooner. You want to knock of as little speed as possible and still make the apex on the correct trajectory to get a perfect exit. This also has the added benefit of allowing you to brake later (because entry speed is higher).
The apex speed is very important, but if you have to brake right after that (and that would be before the corner exit) due to too much speed, push or what ever else, your exit speed will suffer. So, this is a case which goes against just the apex speed as enough to measure effectives of the particular corner execution.
That's why I added "with out botching the exit" to my original statement. I'm am not saying that exit speed is not importaint. I am saying that apex speed is a better indicator of speed. The car is cornering faster because it is now balanced the driver will get on the gas later but will beat or match you at the exit, why? Because he started accelerating from a higher speed (very important to understand) and he had a quicker entry and mid corner so lap time is quicker.
not true see above
Almost there!!
I wrote a reply and then lost it because my connection went down, arg! + I don't know how to do this quote thig correctly, sorry
Fedja [/B]
not true see above
Almost there!!
Fedja [/B]
Guest
Posts: n/a
Hello chronohunter
If you'd like to quote several parts of a message, you need to hit the "quote" button, then "CTRL" + A to select it all, then CTRL + C to copy, then delete the part you dont want, write the reply, then hit CTRL + V and get the whole message again, take what you dont want out again, and so on. Hope this helps.
On the diff question, I think chronohunter is right: if you are really on the limit in a corner entry and open the throttle fully too early, no matter what diffs you've got, you will make the car understeer and therefore not be as fast as would be possible.
If you can change the front / rear bias to 35 / 65, then you will be able to apply the throttle earlier, drifting through the corner. If that is faster depends on the drift angle: if you are slightly drifting from the back, that is generally considered the fastest way around a corner, just slightly over the limit. If you take it Katsuo Kobayashi style
then you are slower, but it's a lot more fun
The ACD will only increase understeer bias when changed from TARMAC. No use, really...
Also, if you are at the limit of the traction (acceleration or cornering wise) and you try to get more, one end of your car will give up. Now the trick is to tune your car so it will give it up into the right direction, so you wouldn't have to lift to bring it back to the line. That is the beauty of it!!
Fedja
Hope this helps!
Fedja
