Boost cut then "service engine" light.
Old Feb 4, 2005 | 10:31 AM
Willie Dynamite's Avatar
So I installed my mbc yesterday and drove around testing it and adjusting it. Today on my way to work I hit boost cut and then my "service engine soon" light came on. Any ideas?
Also, Vw's have Vag-com which reads codes and logs data. Does anyone make something like that for Mitsu? Thanks
Old Feb 4, 2005 | 11:15 AM
bolsen's Avatar
Turn er down
Old Feb 4, 2005 | 11:17 AM
Originally Posted by bolsen
Turn er down
Well yeah, but what do I do about the light.
Old Feb 4, 2005 | 11:19 AM
EVOTEXAS's Avatar
Go to AUto Zone and have them erase it.
Unplugging the battery will turn off the light but it will come back on if the code stored itself.
Old Feb 4, 2005 | 11:23 AM
netmand's Avatar
any ODBII reader that can reset codes will do.
This can be done for free at any Autozone.
Make sure you take a note of what codes it threw. P0234 is what should match the reason why you have the MBC set too high.
Old Feb 4, 2005 | 11:29 AM
93civEJ1's Avatar
you dont have to waste your time going to autozone. Unplug the neg terminal on the battery for alittle while, or just unplug the most left ECU harness plug and plug it back in.
Old Feb 4, 2005 | 11:33 AM
Az3ar's Avatar
I would recommend going to Autozone and pulling the code. The code is not there to get erased the code I there so you would know what’s going on.
Old Feb 4, 2005 | 11:36 AM
93civEJ1's Avatar
and since it's boost cut we can tell you exactly what every other Evo that hits boost cut is gonna say.
now if the code just came on say becuase of normal driving and you didnt know something went on, then yes Id get it checked out.
Old Feb 4, 2005 | 11:51 AM
EVOTEXAS's Avatar
Like I said before, this resets the CEL but does not erase the code from the system. Go to Auto Zone.
Old Feb 4, 2005 | 12:33 PM
netmand's Avatar
you assume too much in my opinion. it doesn't hurt to actually pull the code to confirm.
plus i'm not a big fan of having to reload all of the settings to my audio because it lost all power.
blindly resetting the ECU is not good practice.
Old Feb 4, 2005 | 12:35 PM
93civEJ1's Avatar
actually if you reset the Ecu by pulling the harness you lose no audio settings.
Old Feb 4, 2005 | 01:16 PM
I do want to get the codes read just to make sure. It did come on right after boost cut so I'm sure that's what it is but I'll ckeck it just to be sure. Thanks for all the help.
Old Feb 4, 2005 | 01:17 PM
GBEvo's Avatar
I just did the negative battery terminal disconnect and mine has never come back on. That was about 6 months ago. It definitely can't hurt though to go to Autozone just to be sure.
Old Feb 4, 2005 | 03:01 PM
Az3ar's Avatar
Whatever you like dude. Any pro knows that pulling the code is the way to go and just resetting the battery is kinda dumb.
Good luck
Old Feb 4, 2005 | 10:33 PM
calhoun's Avatar
you can buy a code reader for under $200 which i would highly recomend if you are going to mod your car.
