Turbo Timer
Old Jan 10, 2003 | 02:42 PM
Ren's Avatar
Ren
Turbo Timer
What exactly does a turbo timer do? Why is it so important to have on a turbo car? Thanks for the help.
Old Jan 10, 2003 | 03:12 PM
HobieKopek's Avatar
It allows proper cooling time for oil passing through the turbo in order to prevent damage. Basically it keeps the car running for a set amount of time after the key has been removed from the ignition. In function it's similar to letting the car idle for a couple minutes before turning it off.
Old Jan 10, 2003 | 03:41 PM
Ren's Avatar
Ren
So if you have a stick you just put it in neutral, pull the emergancy brake, turn the key off and walk away?
Old Jan 10, 2003 | 03:46 PM
HobieKopek's Avatar
Pretty much. Install it, park it, forget it.
Old Jan 11, 2003 | 12:49 AM
CooperAWD's Avatar
The car also dies if you try to drive it w/ out the key on... etc.. It should signifigantly increase the life of a turbo.
mmm "baked on" oil.
i "recommend" the new apex A/F Ratio Meter/Turbo Timer
Apex's new Auto Timer is easy to use and great looking too. The control/display head is about the size of a marking pen. It features a manual timer mode as well as an automatic mode. The best feature is that is shows battery voltage, O2 sensor voltage and also A/F ratio. Price includes adapting harness for your year Eclipse.
$110
Its about the price of a normal Turbotimer, but is also a "pretty good" a/f gauge (actually gives a reading... its more than just blinking lights, but its not as good as a good wideband )
www.roadraceengineering.com under new products for the E/T/L catalog.
