HKS 280 Degree cams
Old Feb 10, 2005 | 09:22 AM
fastforward's Avatar
HKS 280 Degree cams
anyone using these yet? any dyno numbers
Old Feb 10, 2005 | 12:49 PM
evo81's Avatar
they just came out.people are still testing them right now
Old Feb 10, 2005 | 01:10 PM
value's Avatar
Don't want to change out springs just for 280's.
Old Feb 10, 2005 | 01:15 PM
evoate's Avatar
Change springs for what? Same lift as 272's, just different duration. I believe Buschur is running them now with stock springs.
Old Feb 10, 2005 | 01:19 PM
alleggerita's Avatar
Longer duration with same lift will equate less radical ramp angles and therefore decreased need for spring pressure. On the other hand, more duration will shift the rpm potential upward which means higher rpm which in turn may mean that you want more spring pressure after all.
Old Feb 10, 2005 | 01:38 PM
value's Avatar
That's what HKS says ?
