ARP head stud install
Old Feb 14, 2005 | 07:53 PM
evoland's Avatar
I've done a search or two and I can't find a good write up on how to do it. Anyone seen a good installation documented on these?
Old Feb 14, 2005 | 08:18 PM
Quickshift's Avatar
Work your way from the middle.Only remove one bolt at a time along with the number sequence below ,torque your nuts to 70 - 80ft lbs. with the moly lube supplied with the headstuds. Hand tighten the studs into the block, and you can give it a couple turns with allen wrench but dont make tight.
This is the order of stud install.
Intake side
8--6-1-3-9
10-4-2-5-7
Exhaust Side
Each of those numbers represent a headstud on the head. Just remove and replace one stud at a time, in that number sequence. The arp use standard sized sockets. After you are finished with your last nut go back through with the torque wrench along with the same sequence and recheck each nut to ensure that they are all at 80ft.
Hope that helps some, use evomoto.com and look at there cam install to get an idea of all the torque specs for all the other items attached to the valve cover.
Old Feb 14, 2005 | 09:35 PM
gonzo's Avatar
EVOMOTO is down.
Old Feb 14, 2005 | 10:01 PM
evo81's Avatar
Originally Posted by gonzo
EVOMOTO is down.
yep,that sucks
Quickshift is right.just listen to him
Old Feb 14, 2005 | 10:22 PM
vtsnake's Avatar
are you serious. i think some of you guys don't know how to use the search feature...
https://www.evolutionm.net/forums/sh...&highlight=arp
chkmgnt59
North Texas Evo Club (NTEC)
Apr 9, 2011 10:23 PM
Magnus82
Northwest Region
Oct 15, 2009 09:49 PM
nothere
Northwest Region
15
Nov 10, 2007 02:55 PM
mrfred
Northwest Region
Oct 4, 2006 11:44 AM
GreddyEvo
Jun 8, 2006 01:17 PM
