Sun Automobile Cyberspeed Hyperground And Hypervoltage
Old Feb 22, 2005 | 12:52 AM
jbigelow's Avatar
these are the newest grounding wires and voltage regulator wires made for the evo from the original grounding originators SUN AUTOMOBILE (they make the wires for the CYBEREVO)
these are supposed to give a little more ponies too!!!!
but i didn't do a before or after dyno, so who knows. but the BUTT dyno feels a little faster.
here is a little more info:
http://www.sunautomobile.com/
click on products and then click on cyberspeed
HYPERGROUND
The H.G.S. Cyber Speed Version is custom-tailored for the best fit and best performance in your vehicle. Giving your car a more efficient ground will help to pull out its full performance potential. The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals. Designed to exceed stringent OEM specs for heat resistance and durability, these cables are the absolute best available. Cyber Speed Version kits have pre-determined mounting points to ensure the best performance and the cleanest installation.
Benefits:
-Increased horsepower
-Increased torque
-Better gas mileage
-Improved throttle response
-Quicker engine starts
-Brighter lights
-Reduced emissions
-Reduced audio noise
HYPERVOLTAGE
The H.V.S. Cyber Speed Version is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released. H.V.S. Cyber Speed Version provides both function and stylish appearance; units are designed to fit perfectly for your vehicle, with specialized brackets and three additional grounding cables. The most secure and reliable mounting locations have been determined by our engineering and design team, to ensure an easy installation and excellent performance. An LED on the unit also operates as a system monitor, to alert you when your battery may need service or replacement.
Benefits:
-Increased torque
-Better gas mileage
-Longer battery life
-Improved battery efficiency
-Reduced emissions
CALL YOUR NEAREST SUN AUTOMOTIVE DEALER or CALL SUN AUTO DIRECT FOR PRICING.
here are a few pix installed in my evo:
Old Feb 24, 2005 | 08:04 PM
J8dailo's Avatar
can you show me the grounding points on this? i have the same kit just lost my instructions... i just grounded some of the basic grouding points...
Old Feb 24, 2005 | 11:13 PM
value's Avatar
I'd be more interested in the MDI ignition setup they run ??
Old Mar 15, 2005 | 11:01 PM
mikiblueeyes's Avatar
Getting shoked
Just installed the same one, followed all the instructions and now i get shoked everytime i get out of the car
Any ideas why????????
Old Mar 27, 2005 | 04:20 PM
johny719's Avatar
nice i'm thinking about picking one of these up myself.
Old Mar 27, 2005 | 05:30 PM
k270kmh's Avatar
Why the guys at sunauto don't know how to explain the difference between these newer produts and the older ones?
Hyper voltage system cyber speed vs hyper voltage system type MR. more power? equal?
Hyper ground system cyber speed vs Sunauto hyper ground system available at Mitsubishi dealer.
Old Mar 27, 2005 | 05:54 PM
J8dailo's Avatar
hyper voltage system is a higher version of the MR model.. the cyber speed version is made for vehicle specifics like sti or evo... the cyber speed version also includes 3 hyper ground wires... i got myself Hot Inazma hyper voltage and grouding system.. this is a limited edition... i grounding different than the instruction... i located my own ground point for more of a clean install.. very nice product nevertheless
Old Mar 27, 2005 | 06:23 PM
mooreboost's Avatar
If I ever managed to eat blue spaghetti, then puke it up all over my engine, it would look like that.
Old Mar 29, 2005 | 12:25 AM
johny719's Avatar
do they only come in blue?
Old Sep 12, 2005 | 10:11 PM
J8dailo's Avatar
he shouldve hide some of the wires...mine was much more cleaner
Old Sep 13, 2005 | 01:38 AM
Did you guys actually noticed any performance imporovement? or is it just mental HP
I had this intsalled for a 1/2 year now and do not see any difference.
Old Oct 30, 2005 | 07:00 PM
MrMejia's Avatar
its not supposed to give any physical feel difference. It's supposed to stabalize and smooth things out if you have gauges or amps or other such things installed in your car. It neutralizes if you have a lot of electric gizmos so that its like you have none. And if you dont have any gizmos, do dads, guages or what not installed and you install this then it will be benneficial in idle, gas mileage and ignition efficiency.
Old Oct 30, 2005 | 08:30 PM
jmartinez1170's Avatar
this has been out for a while man i have to say over a year or so. plus if you knew better its way cheaper to make your own then to buy one off the rack i made mine and i got 25% more spark and when i pull out the plugs they all have the same burn on each one of them. works way more better then the hks one i had and the apex as well do some research before buying grounding kits save your money.
Old Nov 5, 2005 | 06:32 PM
Rmhaffa04's Avatar
Will u post pics of ur install?
Old Nov 5, 2005 | 06:42 PM
genrec's Avatar
I saw a post from gruppe-s on these on socalevo....they said they were going to test it and post up some graphs..i called them out, and have not seen anything back from them yet. this was weeks ago. IMO this is not woth the money and will not provide any benefit, better off spending your money on some other mods.
Kami Speed
17
Apr 19, 2009 09:52 AM
deekay247
For Sale - Miscellaneous Automotive
May 13, 2005 08:04 PM
bonestockevo8
Feb 23, 2005 12:42 PM
RaDZio
Jun 30, 2004 08:49 AM
