Who makes/supplies final gears?
Where can I get a longer gear ratio??
anyone know who sells them and who are the different manufacturers ....
i only know that norris designs has...
thanks
thanks
HKS Kansai sells a taller gear. Talk to ASTROEVO, he runs it. He also verified that it is the same gear in the 2000 Galant you can pick up from the dealer for way less cash. I believe our stock final gear is around 456 and the HKS and Galant gear will put you around 411, don't quote me on this, these are just the numbers I have off the top of my head.
Originally Posted by EVOTEXAS
What about the speedometer, etc when you switch the final drive? Is there anything to correct for this?
See the tiny piece between the ring and pinion, that is the recalibrated speedo.
