Max boost on stock turbo w/race gas
Old Mar 3, 2005 | 10:22 AM
midwestmonster's Avatar
I've seen people running up to 27psi with it tappering to 21-22 by redline. Is this the max psi a stock turbo will hold or would it be better to get it tuned for 24-25 psi on race gas(or alcohol inj.)? Thanks.
Old Mar 3, 2005 | 10:28 AM
matt55's Avatar
29+psi for short time then falling to 22 ish at redline , b4 cams , i read that might make i diff ?
Old Mar 3, 2005 | 10:34 AM
PoorBoys's Avatar
I am running 22 psi on 96 octane. Once I get a better fuel pump I might up it to 24 psi tho.
Old Mar 3, 2005 | 10:38 AM
sleet's Avatar
The stock turbo can hit 29PSI ? I thought the max of the stock turbo was like 24-25PSI?
Old Mar 3, 2005 | 10:39 AM
EVO8 WHOA's Avatar
like i was told by almost every Evo tuner out there, the stock turbo is good til like 20-21 psi anything after that it gets in-efficient and gets so hot that it just doesnt make power. which i believe them now from playing around with mine back when i had a stock turbo i would run constant great power on highway or ne where on 21psi then if i up it to 23-24 i had great power for like a few seconds then it was gone and felt slower than 21 psi because of heat. so ya that i heard from many shops that work with the evo
Old Mar 3, 2005 | 12:04 PM
calhoun's Avatar
i 've heard 24-25 then taper back to 22
Old Mar 3, 2005 | 12:22 PM
sabastian458's Avatar
well upgrade the i/c and run more psi, the factory turbo wide open can make 30+ i have done so, but keep in mind i wasnt running around town that way, the piping keeps blowing apart every time i hit 23 or higher and release the throttle. and yes i have upgraded piping and clamps. but on another note, running race fuel through the factory injectors can and has f**ked injectors, they dont like 110 octane or more.
Old Mar 3, 2005 | 01:20 PM
ldstang50's Avatar
i have 700cc, 255lph and on 110octane i run 30psi across the board
Old Mar 3, 2005 | 01:23 PM
How about some tuners? What do you guys have to say? Buschur, Al, Ams?
Old Mar 3, 2005 | 01:29 PM
gsujeff55's Avatar
26psi tapering down to 20psi at redline is pretty efficient.
