Lifters: hydraulic vs. solid
Old Mar 7, 2005 | 05:22 PM
dryad001's Avatar
Well one of my lifters I think finally bit the dust. The sound is like someone shaking a can with a ball inside. Is this normal? If not what are the pros and cons of soild and hyd. lifters?
Old Mar 7, 2005 | 05:24 PM
1.8t's Avatar
Solid can't float to my knowledge.
Old Mar 7, 2005 | 05:29 PM
EVO8LTW's Avatar
Generally with solid lifters, you can run a more aggressive cam lobe with more lift/steeper ramps and run it to higher RPMs without float because you can get away with much higher valvespring pressure. They need to be adjusted more often though because you'll have a lash spec to maintain. Also, they will tend to be noisier (for obvious reasons) and therefore can cause issues with the knock sensor. To take true advantage of them, you probably need to be revving your car really high and have head work.
Old Mar 7, 2005 | 05:32 PM
dryad001's Avatar
But what about the noise. I've read that this is pretty normal, but it doesn't sound normal. Kinda sounds like a typewriter. If im correct a little thicker oil should correct the problem.
Old Mar 7, 2005 | 05:40 PM
nebolic's Avatar
if you're hearing a tick tick tick noise its normal, all DSM motors have that sound.
Nebo
Old Mar 7, 2005 | 05:42 PM
WildRice's Avatar
Hydraulics do not require lash adjustments, soilds will allow higher revs. Remember that you will probably need valve springs and a tubo upgrade if you want to spin much over 8k.
benIX
Mar 23, 2017 09:29 AM
bryonboals
Jan 17, 2017 04:29 PM
hutch959
Dec 30, 2016 06:41 PM
Howulikemyevo
Jul 18, 2016 11:47 AM
b16a95eg
Apr 30, 2016 05:16 PM
