Please Help...shifting Problem
Old Mar 9, 2005 | 10:54 AM
ShawnJohnPSI's Avatar
Unhappy Please Help...shifting Problem
My car will not go into gear while at a stop, it get's a little easier, but not how it used to be when I pump the clutch pedal. With the car off it shifts through the gears just fine and once I get going down the road it shifts perfectly. I am using the ACT clutch, Fidanza flywheel, and Stainless Steel Clutchline if that helps. Please advise to what this could be...thanks.
Old Mar 9, 2005 | 11:01 AM
SuperHatch's Avatar
Sounds like the clutch wasn't properly bled when the clutch line was installed. If there is air in the system the clutch wont completely disengage and you'll have trouble getting into gear.
Old Mar 9, 2005 | 11:03 AM
jj_008's Avatar
I concur.
