boost leak need help
Old Mar 9, 2005 | 03:08 PM
danny88m's Avatar
Question boost leak need help
I first installed a EBC and i wasnt able to control boost properly.it was either to high boost or to low.i uninstalled and installed a MBC. its been going up between 20-21psi and falls to about 12psi. I've checked hoses and piping doesnt seem to be leaking. i connected everything back to stock and boost stays between 10-12psi no more no less. i finaly came to the conclusion it might be the BOV gone bad. anybodies help will be appreciated thank you.
Old Mar 12, 2005 | 04:43 AM
NC_EvO_GuY's Avatar
my car does the same thing... Sum1 elses car did it too and they bought the stock vaccum setup that runs from the turbo and w/g acc. to the factory boost control soleniod and he said it fixed it and boosted normal again im about to go buy mine today... se i bought my car used and there is sumthin about if you have no b/c and the vaccum lines down there are ANY different than stock it won't boost right... for now i just got a MBC set on 17psi and said screw it! go buy stock vaccum hoses theyre like 13$
