Fluid Leaking
Old Mar 11, 2005 | 07:16 AM
EVO-genetik's Avatar
Fluid Leaking
I woke up this morning and found some fluid leaking
i havent had time to get under the car
but the leak is in between the tie bars
and i was thinking please dont be a differential
but i checked the leak and it seemed to be water
any suggestions?
ej
Old Mar 11, 2005 | 08:11 AM
GTVEVO's Avatar
if it is stock , take it to the dealer. If not try to find out where it is comming from to see if it is going to be somthing simple or not. I could just be a hose leaking or it could be a transfer case seal leaking. Until you find out for sure do the best research possible to find out exactly what it is so you can determine what to do. Don't rip things apart until you have a good plan of attack. Good luck, hopefully it is somthing simple. Remember fluids usually trail along ways from where they start so try to trace it the best you can.
