Question about boost gauge reading?
Old Mar 17, 2005 | 12:55 PM
AcA's Avatar
AcA
I just installed Defi Boost D-Gauge in my car. I have full turbo-back exhaust no cat and Helix Intake. I am idling at -19~-20 psi and my boost taps around 22~24 psi and holds it 18~20 psi. Is this normal?
Old Mar 17, 2005 | 03:30 PM
AcA's Avatar
AcA
anyone?
Old Mar 17, 2005 | 04:00 PM
sweet_bucket22's Avatar
Sounds a little too high to me unless you have mods to support it.
Old Mar 17, 2005 | 04:14 PM
SilverCOEvo's Avatar
Idling at 19-20psi? errr...
ahh...I had the line wrapping before that "-" in the idle section. Sounds about right with the mods probably. And I doubt your idling at -20psi, it's inHg I believe in the negative section.
Old Mar 17, 2005 | 04:21 PM
AcA's Avatar
AcA
yeah I mean in the negative side 19-20 whatever you call it. I just went out and checked again it taps 22 psi and holds 19~18 psi. I am about to put Hallman RX Pro and I want to set the MBC to 21 psi but Im already tap 22 so do I not install my hallman or do you read the boost its holding?????
Old Mar 17, 2005 | 04:30 PM
Personally, I think that it sounds pretty good for the mods. One problem you might be seeing is that the stock BOV (not sure about the MR as I have an 03) is only good to about 21 psi. So if you're hitting 22 (and plan on being in that range), I'd think about a new recirc/BOV as well as the MBC. I'm definitely not a pro in this area, but from what I've read you're not in a "scary" place by any stretch of the imagination.
I would say that 22psi is a bit high if not properly tuned to match, but it's not "BAD" high. And getting a little taper in the high RPMs isn't abnormal, but others can probably chime in here with more information.
Old Mar 17, 2005 | 04:54 PM
AcA's Avatar
AcA
I have an 05 evo. When setting an MBC do you set it psi to where it taps or where it hold. For example I am taping 22 for a quick moment and hold at 18~19 psi so when I put MBC tommorow do I raise it so it holds 21 or down my boost so its taps 21. I want to set it 21 psi.
Old Mar 17, 2005 | 07:01 PM
I'd set max boost at 21, I'm planning on doing that quite soon myself. Unless I get a tune for more (and I will be getting a tune once I add a couple more mods), I think it's safe and I expect to get a slight taper.
Old Mar 17, 2005 | 07:23 PM
AcA's Avatar
AcA
bummmp
Old Mar 17, 2005 | 11:13 PM
turbolarry's Avatar
Set your MBC to hold 21psi.
It will spike (tap) a couple of lbs. higher for a second.
Old Mar 18, 2005 | 04:59 AM
AcA's Avatar
AcA
i see...thanks anyone else have different input on this?
