Question about Perrin Oil Catch Can
Old Mar 20, 2005 | 01:10 PM
Evo23IG's Avatar
I have had mine Perrin Oil Catch installed on my car for about 3000 miles, today I took it off and opened, there was no sign of oil in it. Is that right? I have two lines running, one from the valve cover and second from the intake. Could it be set up wrong??
I used this install for guide:
http://home.earthlink.net/~ejhonda/evoPerrin.html
Old Mar 22, 2005 | 09:09 AM
Evo23IG's Avatar
Bump for an anwer or help.
Old Mar 30, 2005 | 10:00 PM
mifesto's Avatar
make sure it is a closed system, make sure no nipple or plug is free. only the 2 tubes should connect to the valve cover nipple and the intake. also if the tube is either too big or there is a big gash, there will not be any vacuum effect. and finally catch can is more effective for a stock evo, as the stock ecu is tuned very rich. once your evo is tuned, you will get very little oil. hope all this helps
Old Mar 30, 2005 | 10:02 PM
mifesto's Avatar
i also wanted to say it may take longer then 3000 miles to get any sign of oil in your catch can. i recommend to people to get clear vacuum tube because then you can easily see that oil IS building up in the tubes as well as the catch can.
