hks ssq owners please read
Old Apr 4, 2005 | 05:43 AM
Derek888's Avatar
Did any of you do this mod to make it work? Who is using VTA on the stock MAF with no problems? thanks
Originally Posted by Coolguy949
I've installed about 15 HKS BOVs on evos and not one problem recirculating. There a couple things you need to buy to make it work with the evo. First, you need to buy a 1 inch radiator hose (about 1 inch long too) because the recirc nozzle isnt wide enough for the hose clamp to fit around it in the dump hole on the turbo inlet pipe. Next, you need to buy about 4 inches of vacuum hose since HKS doesnt include the smaller hose (stock is too big) and they just include the big to small adapter.
Old Apr 4, 2005 | 07:19 AM
BigAeVo's Avatar
im running a HKS VTA bov with no stalling at all, i do have a SES light on but it may or maynot be from the BOV.
Old Apr 4, 2005 | 08:01 AM
si_eater's Avatar
how come im having a problem with ever since i put it on, it was always recirced
and i still have the idle drop and sometimes stall at low rpms or engage clutch coming to stop, i even tried the eids, no dice
Old Apr 4, 2005 | 08:18 AM
PSIbabi21's Avatar
i have the same problem with it, so does my boyfriend!!! they are also both recirced and i still get the idle drop, bounce, then stabelize or stall!!
so no worries, your not the only one!
Old Apr 4, 2005 | 09:07 AM
gonzstarr's Avatar
i don't have the ssqv, but my buddy matt has it, he ran it VTA with NO PROBLEM. same goes for Val(dragonfly), she runs hers VTA with no stalling. Once i install mine i'll let u know. All evo engines are, to some degree, different.
As far as know, you shouldn't have a problem.
