Can you adjust the MAF (VAF) ??
Old Apr 10, 2005 | 05:40 PM
mikey19's Avatar
Question Can you adjust the MAF (VAF) ??
I was talking to my local tuner guy ealier about vta type blow off valves and the mass air flow sensor problems. He said blah blah, how the ecu can adjust itself. Then he offered to tune (adjust) my MAF. He told me that there is this screw on the bottom of my MAF and the can turn it to allow more air in, which tells the ECU to give more fuel. If i have a VTA BOV, doesnt that mean my car already is running a little rich? is he correct about the MAF adjust? I told him I would get back to him on Monday whether if i want to adjust or not... Does anyone know about this?
P.S. i did a search until 6am this morning about MAFs
thanks very much
Old Apr 10, 2005 | 08:06 PM
mikey19's Avatar
any one know about this??
plz help
Old Apr 10, 2005 | 08:15 PM
vletnguyen's Avatar
you cant adjust maf. there is no screw.
hks eids will help vta bov's or stand alone ecu for speed density.
maybe blow by with utec?
Old Apr 10, 2005 | 08:24 PM
GOKOU's Avatar
You can't adjust the MAF. I think it's the screw on the throttle body that he's refering to.
Old Apr 10, 2005 | 08:51 PM
MalibuJack's Avatar
I've seen a few different mitsubishi MAF's.. I don't recall seeing any of them with an adjustment screw. Its possible he's thinking of the 1G DSM MAF, I have never seen one of those up close to know anything about them.
The ECU is capable of adjusting to some conditions, but a VTA condition is where you release air from the induction system after it has been metered, which means that the computer thinks there's more air so it adds more fuel, you release the air and get a very rich condition.. Of course there are other MAF anomolies that happen to cause stalling that tweaking can help, besides the BISS setting (Basically an Idle adjustment) there's very little to physically adjust under the hood.
There are no really good inexpensive solutions to allow you to use a VTA valve, and its not recommended on the evo unless you are running something capable of tolerating the venting (something that meters after the valve)
The HKS EIDS is capable of helping this, but it does it at the expense of throttle response and to some extent other forms of drivability.
do a search, this has actually been discussed umpteen times in the past.
Old Apr 10, 2005 | 11:26 PM
turbolarry's Avatar
This is what he's talking about;
http://www.roadraceengineering.com/e...adjustment.htm
I didn't check mine when I had it off, so I don't know for sure if it applies to Evo's too.
Old Apr 11, 2005 | 05:36 AM
mikey19's Avatar
wow, nice info , thanks a lot. I guess I shouldn't even mention about adjusting that MAF screw to the tuner. For some reason, my car idles fine even w/ a VTA BOV, w/o any adjustments.
Kralster
Lancer Troubleshooting
Jan 11, 2023 10:26 PM
GrnEVO
35
Feb 1, 2011 03:47 AM
Stradag
Jan 3, 2010 04:26 PM
DSM97HERO
Sep 21, 2008 06:24 PM
Jameson_IXMR
Feb 24, 2008 01:25 AM
