Weapon*R engine damper fix
Old Jun 16, 2005 | 02:50 PM
  #31
Tsurara's Avatar
This is very cool, way to go WeaponR
Old Jun 19, 2005 | 02:22 PM
  #32
Syrihl's Avatar
Got my new replacement bracket yesterday and reinstalled it today. Clearances were a little tight like before, but everything barely cleared with a little tweaking. The new bracket looks just like the pictures that Ray posted before; it's got two more reinforcement plates welded on and is painted black. I had forgotten how much smoother the damper makes high RPM shifts. Here are some pictures:
Old Jun 19, 2005 | 11:08 PM
  #33
revolagoy's Avatar
Got mine also. It didn't fit. The tolerances were way too tight. I ended up taking apart the damper and cutting down some of the rubber and also removing one of the spacers on the end. It is in there very tight. No movement at all. It also hits the hose right next to the cam cover. I am hoping it doesn't wear through the hose over time. I'll keep an eye on it.
By the way, the new bracket feels very solid! I doubt this one will break. I watched the engine with the hood up as I started the car. No movement at all. Has anyone noticed that there diffs clunk more? I hear the diffs clunking every time I back up. It sounds like someone hitting the bell housing with a small hammer. Used to hear this once in a while, now it is all the time.
Old Jun 19, 2005 | 11:51 PM
  #34
Syrihl's Avatar
Yeah, if you look at the first picture I removed the nut that was on the end closest to the front of the car. This reduced the length of the damper by 1 cm or so, enough to make it fit. That hose that runs right above the new bracket does barely touch one of the new reinforced areas, but the bracket for the hose could probably be bent to solve that. Yep, my car has always made that clunk when backing up, especially if it's the first time driving the car for the day.
Old Aug 5, 2005 | 07:00 PM
  #35
sirploppy's Avatar
Any news on when these fixed units will be back in stock? I ordered mine from ProStreetOnline.com over a month ago and they said it would be in this past week... So far nuthin...
Old Aug 5, 2005 | 08:13 PM
  #36
nutnbutturbo4's Avatar
Ray i sent you a PM and a Email.... Thanks again
Old Aug 5, 2005 | 08:40 PM
  #37
Jakeg97's Avatar
Originally Posted by Syrihl
looks good
i just emailed for my replacement
Old Aug 5, 2005 | 08:56 PM
  #38
mooreboost's Avatar
They still can't get it right even after the second time around?
Old Aug 6, 2005 | 07:02 AM
  #39
BMan's Avatar
If you move your ac hose mount to the outboard hole and flip it over, all of the clearance problems go away. Doing this will lower the hard pipe away from the shock tower mount and change the angle to the ac pump so it has much more clearance at the motor mount bracket. It's almost like planned for this mod in early development.
Old Aug 6, 2005 | 07:13 AM
  #40
nhsean69's Avatar
i dont own a Damper yet, but if this is what i can expect for service.......i think i would like to own one!! Props!
Old Aug 15, 2005 | 05:28 AM
  #41
bryans2k's Avatar
The only problem with the fixed one is that it now puts the unit very close to your cam gears so there is a very good chance of them touching if you have aftermarket cam gears... It's like 1-2 mm away from the nut/bolts... bites...
bryan
Old Aug 15, 2005 | 05:44 AM
  #42
Evo007's Avatar
bryan
Isn't that why you have a cover over them?
Old Aug 15, 2005 | 09:42 AM
  #43
bryans2k's Avatar
I guess you don't know exactly how small 1-2 mm is... lets just say the cover has no chance of fitting...
bryan
Old Aug 15, 2005 | 11:19 AM
  #44
RKT SHP's Avatar
i just sent a email
Old Aug 15, 2005 | 11:49 AM
  #45
Evo007's Avatar
bryan
Oh, wow misread your original post. I don't think it's suppose to fit like that. You should be ablt to use your stock gear cover with it.
