does anyone have this problem?
Old Apr 13, 2005 | 06:54 AM
si_eater's Avatar
i just recently had my twin plate clutch installed (exedy) and im having a problem. when im about to come to a stop i press down on the pedal to get out of gear and supposedly the revs come down and the stick just slides out of gear but mine the revs dont come down and i sort of have to pull hard to get it out of gear i didnt do it before i went back and had the guys that installed it adjust it (or at least thats what they told me it needed)it cured the problem for a little while but now its doing it again, it only happens sometimes and it doesnt do it when im pulling out of my neighborhood, it does it when i have driven it for a while, i was just wondering if anyone has encountered this problem, and if you have what did you do to fix it, it seems that just adjusting the pedal doesnt cut it, or if anyone has any idea what it could be.
thanks for the help
Old Apr 13, 2005 | 07:00 AM
redevo561's Avatar
Bro check your slave cylinder, bleed it might have air in the lines and not enough pressure to engage and dis/engage the clutch
Old Apr 13, 2005 | 07:03 AM
si_eater's Avatar
thats what i thought, but wouldnt the pedal go all the way down and i dont have a problem shifting through the gears, or or getting into gears, or does that matter ?
Old Apr 13, 2005 | 08:02 AM
si_eater's Avatar
ttt
Old Apr 13, 2005 | 10:12 AM
si_eater's Avatar
bump
Old Apr 13, 2005 | 01:03 PM
si_eater's Avatar
does this mean im alone on this one
