Starting COP set up
Old Apr 26, 2005 | 02:47 PM
dryad001's Avatar
Starting COP set up
Well here is the info that I got off of the AEM forum. It seems that the Chrysler 300m coils seem to be a good fit but to mount them the top cover needs to be replaced with a new one that will be tapped to hold the new coils. Then to connect the coils to the wiring to either the CDI or C2DI you will need Toyota connectors with the PN 90980-11246 along with the pigtail wires PN 82998-12440. On top of all this is the ignition box and the ever elusive wiring diagram for the evo. Everything together is about 300-600 including the AEM ignition box. For the people that have done it is there anything else I need?
Old Apr 26, 2005 | 03:31 PM
kcevo's Avatar
The wiring diagram for the evo is the same for the eclipse. BTW, don't use the pdf manuals that are from the AEM instructions or what came with the C2di as they tell you to wire coils 1 and 3 together when wiring them in series.
Here is the diagram I saved from the AEM forum for wiring them up.
Old Apr 30, 2005 | 05:51 PM
fcheng118's Avatar
I'd like to see some set-ups also
