Installed my JDM Diverter Valve tonight (MUST READ)
Old Apr 27, 2005 | 07:58 AM
crusin_lancer's Avatar
Originally Posted by UFO
Not everybody. My plastic DV holds boost better than the MR one. The MR DV also causes my car to stall. I put the plastic one back on after a few days and it ran great again. (yes, it was installed correctly)
And why is this a must read? There have been tons of topics covering the MR DV and you're not exactly the first to try this component in a US Evo...
Very true. Some peoples cars like the stock DV over the MR DV and have ran really ****ty with the MR DV. I haven't had this experience and I think the MR DV was worth every penny.
Old Apr 27, 2005 | 09:28 AM
RAWMR's Avatar
Is there a difference between the US MRDV and JDM MRDV?
RAW
Old Apr 27, 2005 | 09:29 AM
UFO's Avatar
UFO
RAW
Yes, the US MR comes with the same plastic DV as the regular Evo. The JDM MR comes with the metal one.
Old Apr 27, 2005 | 06:49 PM
Timujin's Avatar
any pics of the plastic one off the car?
Thanks.
Old Apr 27, 2005 | 10:52 PM
evo8chris's Avatar
im happy with mines. holds makes my car feel solid.
Old Jun 18, 2005 | 07:32 AM
PapitoEVO8's Avatar
Are there a sites that have it in-stock right now?
Old Jun 18, 2005 | 07:54 AM
fromWRXtoEVO's Avatar
I was wondering how does the MR JDM compare to the metal BOV from the first gen Eclipse which is also metal.
Buschur racing sells the upper intercooler pipe with the first gen Eclipse BOV, they also kind of look identical.
I heard from so many second gen Eclipse owner that the 1st gen eclipse BOV was listed as one of the first mods to hold boost.
Any feedback on that? Thanks!
Old Jun 18, 2005 | 07:58 AM
turboDan's Avatar
Switched from JDM MR BOV to stock one while awaiting install of buschur upper I/C pipes,did nothing else(Had sold JDM MR BOV,thats why the switch)and lost 2lbs of boost,thats right 2 lbs of boost,WOW.Took all of about 10 minutes to change,so weather and engine temps had nothing to do with loosing 2 lbs of boost.Other than that driveability and everything else was the same,just the 2 psi loss was all(no,there was no boost leaks created from the change over).In conclusion,2 thumbs up for the JDM MR bov,and the stock plastic one is a POS.
Old Jun 20, 2005 | 11:54 AM
l2edline's Avatar
will the jdm DV void my warranty??
Old Jun 20, 2005 | 01:34 PM
Doug@WGP's Avatar
as far as I could tell.. both the JDM and the stock valve hold 21psi with no probs, but the JDM valve made my car stall out if i slightly tapped the throttle while parking, etc... so I switched back to the stock valve...
Old Jun 20, 2005 | 03:10 PM
fixem2's Avatar
Will the JDM MR DV hold 24 - 25psi?
Old Jun 20, 2005 | 03:26 PM
I think the JDM MR DV is capable to hold at least 24psi.
Old Jun 20, 2005 | 03:37 PM
nirvevo's Avatar
Slightly... (very slightly)... off topic, but I knew that my 03 black plastic was leaking above 22 psi, so I bought the Greddy type S and sealed up the leak, had to turn the boost back down a bit afterwards because of the replacement.
Just wondering why you guys are choosing the DV over a BOV? I try to avoid the bling factor whenever possible, but I liked the adjustability of the Greddy for different boost levels.
Somebody fill me in.
Thanks
Old Sep 9, 2005 | 08:30 PM
PapitoEVO8's Avatar
Mines is on the way
