MBC with SAFCII?
Old Apr 26, 2005 | 09:02 PM
dreamevo's Avatar
MBC with SAFCII?
I've just installed a SAFCII. I am going to install a MBC sometime soon.
Does it make any difference tuning the SAFCII with or without a MBC??
Old Apr 27, 2005 | 01:08 AM
turbolarry's Avatar
Are you on stock injectors?
Old Apr 27, 2005 | 05:05 AM
ebbeast2005's Avatar
yea as long as you dont have upgraded injectors work with more boost and ect. Do you have a boost controller
Old Apr 27, 2005 | 12:03 PM
dreamevo's Avatar
Yes, I still have the stock injectors. So, will I need to change the AFC setting when i have a boost controller??
Old Apr 27, 2005 | 12:50 PM
turbolarry's Avatar
AFC's and MBC's are like bread and butter, Sunny and Cher, Jack and Coke... they just go together. A MBC is more desirable because it holds boost better than the ECU, no tapper, and rocks up faster. You can tune on the stock solinoid, but a MBC makes tuning the AFC easier. Set your MBC to your desired boost (make sure you have a logger) and tune away;
http://www.evotuners.net/forums/showthread.php?t=335
Injector size is a bigger factor when tuning the AFC. That's why I asked.
Old Apr 28, 2005 | 07:36 PM
dreamevo's Avatar
Thanks... ordered my MBC already... should be here anyday now..
Will install the MBC before tuning the AFC.
