highest boost at stock?
Old Apr 28, 2005 | 05:33 PM
JSYEVO's Avatar
this has probably been covered a numerous amount of times and i have searched but didnt find the exact answer i wanted. im planning on getting a hallman MBC hks dp, hipower exhaust, and intake (just the filter). im still not sure about what im getting first. i read that the modifications will cause spikes and the mbc cant control it as well as a ebc would. so my questions are: will a dp exhaust and intake affect the MBC? should i stick with the mbc or get an ebc? what should i get first second ect.? with the mbc, dp, exhaust, and intake, would i be able to hold a steady 19.5 or 21psi? thanks a lot (sorry about the length!)
Old Apr 28, 2005 | 08:03 PM
plokivos's Avatar
you could hold up to 23psi.
get a flash, you could go up to where ever on boost.
I think alky injector holds 28psi easy without blowing up the engine.
Old Apr 28, 2005 | 08:10 PM
JSYEVO's Avatar
i dont really have the time to send in the ecu ect. all i want to do is 19-21 psi and the questions i listed is all i want to know...thanks anyways!
Old Apr 28, 2005 | 08:13 PM
mooreboost's Avatar
Get the MBC first, set it for 20psi.
Stick with the stock intake.
And a full TBE may effect boost slightly, just adjust accordingly.
Old Apr 28, 2005 | 08:14 PM
bigjhoney's Avatar
With the mods you have, i dont see a problem running 19/20 pounds aslong as its atleast 93 octane without a flash, a flash will get you more power though.
Old Apr 28, 2005 | 08:15 PM
DCSilvrEvo's Avatar
I hold 21PSI till 7000 I dont spike.
Old Apr 28, 2005 | 08:19 PM
JSYEVO's Avatar
what are your mods?
