BR330 question
Old May 2, 2005 | 01:54 PM
2faast4u's Avatar
BR330 question
I was bored and was looking at the specs for buschurs evo package available at medina mit. why did he use a 2.5" dp and go to a 3" exhaust??? why not go with a 3 " dp.....
Old May 2, 2005 | 01:58 PM
bdking57's Avatar
If you do some research youll find that some people think 3" is to large for the stock turbo and slows the gas through the exhaust or may have some other negative effect. IMHO i think 2.75 is optimal buts its the most expensive to produce because its an unusual size. a 2.75 down pip should cost more money then a 3".. which is why 3" are probably pushed on eveyrone so much.
Old May 2, 2005 | 02:01 PM
2faast4u's Avatar
oh yea, now i remember seeing a thread on this. No one could agree though. some people thought less restriction after turbo=better spool and some people said 3" was just too big and had - results.
matt55's Avatar
no , he did it so it would not bottleneck at the stock cat , they kept the stock cat for emissions or something like that
Old May 2, 2005 | 02:03 PM
2faast4u's Avatar
that makes more sense
Old May 2, 2005 | 03:14 PM
Hiboost's Avatar
Yes since it's a new car I think officially they can't replace the cat unless it was defective... of course not flowing enough for the engine output could be considered a defect of sorts! Basically you wouldn't want a 3" downpipe feeding a stock cat and then going back to a 3" Cat back. If the stock cat is considered a restriction on a stock exhaust then it likely flows only as good as a 2" pipe at best. I wonder how much CFM a stock cat versus high flow cat versus 2.5" versus 3" pipe looks like with flow coming out of the typical 4G63.
Old May 2, 2005 | 05:49 PM
03BREvo8's Avatar
youd lose tones of pwr if you used the 3" with the stock cat... ... only with a high flow or test pipe do you want to use 3" or larger...
a4rontran
Aug 26, 2011 09:06 AM
morfhious3
12
Aug 3, 2009 05:59 PM
syclone2032
Feb 11, 2008 03:56 PM
daesup45
Oct 24, 2007 03:11 PM
apagan01
10
Aug 20, 2007 08:27 AM
