BOV Supply hose.....
Do i need to make sure that the boost supply line is the stock size?? If it isnt will it cause the bov to leak? i have sorta asked around about this but im still unsure of the answer.....
btw the reason i ask is i have a boost leak i have been chasing now for some time..... not sure if one of my ic pipes has a hole or what... basically i need to pressure test the system but never really have the time too...
ooo ic, see i have smaller than the stock diameter and i was thinking it wouldnt flow enough air to keep the bov closed......o yeah it also goes into a T which then makes it even smaller.... which means less air flow..... So could this be causing my high rpm leak??? i get a leak about 6500 rpm that sounds like the bov opens and just is throwing air....
