Would u get 272 cams if your car is stalling?
Old May 3, 2005 | 06:21 PM
LancerEVOmann's Avatar
My Evo will stall sometimes when in low rpms in 1st gear, like when I am slowing down. It has gotten better with a grounding system, but still happens. It is even worse with the AC on. I am going to get a 02 simulator hoping it will help.
But I want to get HKS 272 cams for mid and high end power, but I heard they run rough at idle and can make the car stall. Well, since mine is stalling sometimes already I was wondering if it could make it stall like all the time. Or maybe could it be stalling because of a boost leak somewhere? Would would u do?
Old May 3, 2005 | 07:17 PM
03BREvo8's Avatar
Make sure you SAFC is set for 4 cyl not 5 or 6.. that makes a big diff.. or your TT is wired wrong... check and check again.... make sure you MAF is also hooked in all the way....
Old May 3, 2005 | 07:18 PM
03BREvo8's Avatar
The o2 sim will not effect idle or rpms... it is basiclly just for inspection purposes... just gets rid of the cel...
Old May 3, 2005 | 07:20 PM
SilverEvo8owner's Avatar
Is your BOV VTA?
Old May 3, 2005 | 07:26 PM
MalibuJack's Avatar
I honestly wouldn't do the cams until your have your idle problem resolved.. sounds like you may have a vacuum leak somewhere, or if your BOV is a VTA or I think it can do both, and you have too much air bypassed and not enough recirculated.
Old May 3, 2005 | 07:40 PM
timzcat's Avatar
I am guessing the AROSpeed air filter is an intake pipe and filter?
That would be the cause of the stalling. You can tune around it with a flash.
At least I know Al can, I don't know if that is a trick of his or if TT would be able to do it.
Old May 4, 2005 | 01:32 AM
tlclee's Avatar
My 272/272 doesnt stall....sounds like a v8 tho.
Old May 4, 2005 | 04:34 AM
SuperchargedGTZ's Avatar
i have had a crappy idle for about 10 months now ever since i installed my buschur intercooler with piping kit. and now it is even worse now that i put my buschur turbo inlet pipe on. once i finally go and install my 264s at pruven i will ask them to check everything out.
Old May 4, 2005 | 05:14 AM
Originally Posted by SilverEvo8owner
Is your BOV VTA?
I have the GFB Stealth BOV, u can put it to total recirc or VTA, right now I have it set to 50% recirc and VTA. I know ppl that have total VTA BOVs and they don't stall like mine.
Old May 4, 2005 | 05:32 AM
No, just the filter is aftermarket. The MAF pipe is still stock.
Old May 4, 2005 | 05:33 AM
Do u know how much the stealership would charge to look for a vacuum leak? Would they test each hose?
Old May 4, 2005 | 05:35 AM
Do u have a recric BOV or vta?
Old May 4, 2005 | 11:27 AM
bdking57's Avatar
Its your GFB bov. Yes you can run it fully recirculating but you have to play around to get the right settings. I know exactly what your car is doing because mine would do the same. I would stall everytime going up a steep incline or when letting off the gas.. not so with the stocker, although the stocker definately leaks boost.
Old May 4, 2005 | 12:19 PM
MalibuJack's Avatar
Probably an hourly rate.. Unfortunately I don't have a high opinion of many dealership mechanics.. I stopped bringing my car to the dealership when I realized I was much better at troubleshooting problems than they were. I just bring my car in when it needs recall work, or to have something done that they can't possibly screw up.
Old May 4, 2005 | 02:04 PM
vegeta irie's Avatar
Dude I got the GFB with an aftermarket filter. Mine used to stall all the time. I set it to fully recirc. and then reset the ECU. And it worked. It is still loud enough for my taste w/the filter. hope it helps
