Changing the Hotside...
Old May 9, 2005 | 11:16 AM
BOOSTEZ's Avatar
All:
Oh my God. This is going to be a job. The part is cheap. The labor is ridiculous. Here's my dilema: I could attempt to change it myself (with another mechanic friend) and risk messing up bolts, etc.. and get the best bang for my buck - only the cost of the housing. Or I can let RnR do it for $350 + cost of another day off of work. Or I can let the dealer do it for $450 + new gaskets, etc.. and don't have to worry about any mess ups and still have a warranty if something goes wrong.
What do you guys think?
-M
Old May 9, 2005 | 11:23 AM
ultraflip's Avatar
dealer... only because i'm a warranty *****...
how much did you get the housing for if you don't mind me asking?
Old May 9, 2005 | 11:24 AM
Aby@MIL.SPEC's Avatar
give rre a call, they charge a lot less, ~$200-250. search for their number "road race engineering.
Old May 9, 2005 | 11:26 AM
sleet's Avatar
I hate paying for labor so I think if I ever try to do that mod i'd try it myself, but if you're worried about the warranty and all that then i'd have the dealership do it...although I hate them touching my car.
Old May 9, 2005 | 11:31 AM
BOOSTEZ's Avatar
Yea, I've set up an appointment for the dealer for tommorrow. I really don't mind the extra cost in labor if I know the car will be covered under warranty.
The housing cost me $250+shipping from www.forcedperformance.com
-M
Old May 9, 2005 | 11:36 AM
bolsen's Avatar
I'd say do it yourself. You'll learn about it, you'll have an understanding of it, you'll have a better appreciation of it, and you'll have a good sense of accomplishment from it.
Sounds silly, but it's true.
Old May 9, 2005 | 11:43 AM
turboDan's Avatar
Just remove turbo/exhaust manifold and o2 housing all as 1 unit,can have it off in 1/2 hour if you have never done this before,as the most time consuming part is removing the undertray and you really dont even have to remove that.Then you have the whole unit in front of you for easy removal and if anything goes wrong you can easily bring unit to someone with torches to have nuts/bolts heated up for easy removal.BTW,you dont even need to remove rad to do this.
Old May 9, 2005 | 11:45 AM
BOOSTEZ's Avatar
I've changed several turbos before, so I know about the feeling of changing one out. However, I've also done work to my other cars and have had things start breaking shortly after. I feel like going to the dealer and saying I have a leaking exhaust manifold is asking for trouble.
I'm going to play it safe and get it done by the dealer.
-M
Old May 9, 2005 | 11:50 AM
SuperHatch's Avatar
Do it yourself...
https://www.evolutionm.net/forums/sh...d.php?t=132695
Old May 9, 2005 | 12:08 PM
Evo007's Avatar
I'm planning on doing it myself. No need to get someone to do the install. Doesn't look that difficult.
Old May 9, 2005 | 12:50 PM
rsboy's Avatar
wait... you seriously think having the dealer change the turbo hotside for you keeps you under warranty... if that part breaks??? I find that hard to believe that they would actually honor that.
Old May 9, 2005 | 01:02 PM
marksae's Avatar
If you've changed several turbos before, this shouldn't be too bad. Just make sure you spray a lot of penetrating lube on all the bolts before you attempt to crack them loose.
Old May 9, 2005 | 01:46 PM
BOOSTEZ's Avatar
Yeap. The mechanic told me that he would take responsibility for it.
-M
Old May 10, 2005 | 01:26 PM
rsboy's Avatar
-M
Nice. That's a good dealership.
But you mgiht want to get that in writing from the Service Manager and local Mitsubishi warranty rep... just in case the mechanic decides to work for the Honda dealership next door, after he installs your turbo hotside. Just in case...
Old May 10, 2005 | 01:27 PM
03BREvo8's Avatar
You dont want to mess up the balance.. doesnt the new hot side come with a titanium shaft?
