hallman mbc tapers down 21-19 psi
Old May 17, 2005 | 06:54 PM
yesevo's Avatar
its holds boost fine below 5k rpm,but at above 5 or 6k rpm it tapers down to around 19psi by the time i reach like 7300rpm in 3rd gear.. i dont think i have any leak ,,,
anyone holds boost rock solid all the way? even at 7500rpm?
Old May 17, 2005 | 07:03 PM
plokivos's Avatar
your BOV. it sucks.
there is a way to do that without changing the BOV, but if I tell you, I have to kill you.
It's a driving technique.
But that happens. Mine peaks at 23 psi, and after 5000rpm, it starts to taper down about 1psi to 2 psi.
I heard MR BOV helps.
Old May 17, 2005 | 09:12 PM
Thoe99's Avatar
Does it still taper if you turn your MBC down to (say 13psi)?
Old May 17, 2005 | 09:21 PM
plokivos's Avatar
Widebandphillip's Avatar
sounds normal to me. The turbo can't pump much at high rpm (6k and up)
Old May 18, 2005 | 04:41 AM
deadbeatrec's Avatar
all turbos bleed off some boost at high rmp range unless u have a huge turbo. if u want to know if ur boost is holding put it in forth at a low speed(35-40) and gradually put the pedal to the floor.
Old May 18, 2005 | 01:09 PM
SJ EVO 8's Avatar
And???????Whats it supposed to do??
Old May 18, 2005 | 02:18 PM
Thoe99's Avatar
