clutch adjustment problems!
ok i am having a problem shifting @ high rpm's so this tells me i need to adjust the clutch a bit because i guess it isnt dis engauging fully..... anyway here is the issue the nut you have to loosen is on so tight i cannot get it to break loose! any idea's???
try using pb blaster. you can get it at wal-mart in the auto section. it has a yellow cap, is white with black lettering. it is like wd-40 but way better. just spray it on, let it sit, and try it again. i have gotten many hard to break nuts and bolts out with that stuff. hope this helps.
Paintball the mechanic. I hate to say it but... vicegrips. Use two pair; one to put load turning what's left of the nut, and one to turn the rod the same direction. By trying to turn the rod at the same time, it will help turn the nut. Obviously you will need a new nut anyway, and if you don't like how chewed up the rod gets, replace that too.
yeah it sucks *** and yeah the mechanic will get his soon enough. They did lotsa damage to my car when putting the clutch in..... turned into about a 5 month ordeal with my car sitting the entire time.......
ACTman,
what do you think that I went through 2 sets of ACT clutch and experienced the shifting problem at high RPMs? I did do the adjustment but it only temporary improved the situation (I said improved because I still have to "muscle" it it). I just want some opinions to share with fellow members who may have problem at the drag.
Sorry for the confusing. I mean "muscle" the gear in when shifting, not the nut when adjusting the clutch.
Originally Posted by dafarmer69
muscle what.. the nut is hard to break loose but it has to be done.. then turn the shaft in towardsthe fire wall.. mine went in alot.. but oh well..
Originally Posted by G20
ACTman,
Drop me an email and we can discuss it further.
