check ecu code ?
Old May 23, 2005 | 07:19 AM
nils's Avatar
check ecu code ?
How do you check to see what code the ecu is throwing?
I searched. I am new to EVO. help.
tia,
nils
Old May 23, 2005 | 07:21 AM
Silver05Bullet's Avatar
You need a scanner with OBD II connection, or just go to Autozone and let them check it for you and erase it if its something dumb, they do that for free.
Old May 23, 2005 | 07:25 AM
nils's Avatar
thx.
Old May 23, 2005 | 07:34 AM
taenaive's Avatar
or, buy ODBII scanner to check. They will charge you like 60 dollars to just check and erase the code. you can get a scanner that can read and erase the code for like around 150 dollars. Also, that scanner can acts as a logger. That is when you have a laptop or palm of course.
Old May 23, 2005 | 09:04 AM
nils's Avatar
cool thx...
first time dealing with codes being thrown on a OBD II....
I'll look into just buying a scanner.
n
Old May 23, 2005 | 09:07 AM
KazzEvo8's Avatar
There are cheaper scanner/reset tools to be had although I've not seen a specific recommendation on the board. And Autozone won't charge you to read and reset - nor will Advance Auto based on my experience. YMMV...
