how to take off the timming belt?
all. you need to do is losen the tension on the belt and slide it off..theres a small hole on front of the timing belt cover and you need to put the belt tensioner tool and undo the tension..that should be it...putting it on is another thing..gl
you can search on the forums for the rod that can be used instead.. it cost me 2bux and is 2ft long. bad thing is you cant use them more then 2x.. (cut it in half for 4x)
