Question about gauge sensor locations
Old May 27, 2005 | 12:35 PM
Mikey52's Avatar
Im getting ready to install some gauges soon and I wanted to clarify where the sensors went for them all.
Boost Gauge: T off the fuel pressure regulator line
Oil Temp: Drill and tap into the oil pan -- Into the side or bottom (I assume side), and how far up from the bottom of the pan?
EGT: Drill and tap into the exhaust manifold -- 2 inches in on one of the runners? If I plan on getting the manifold ported, polished, and coated should I drill before or after?
Wideband: Bung gets welded into the downpipe? -- I dont actually have this yet but was thinking about having the bung welded onto my exhaust before I install it.
Old May 27, 2005 | 12:37 PM
Nez136's Avatar
not sure about the Oil, but it looks like everything is right
Old May 27, 2005 | 12:59 PM
Mikey52's Avatar
Actually, the more I read it looks like the oil temp sensor can just screw into the drain plug? I have Autometer gauges if that makes any difference.
Old May 27, 2005 | 01:04 PM
djmikeymike's Avatar
you might what to check this out ..... http://www.z1auto.com/prodmore.asp?m...ne&prodid=1142
Old May 27, 2005 | 01:18 PM
Mikey52's Avatar
This is what I have, it looks similar to that. Im not sure if the sizes are wrong though.
