hallman short rx kit install?
Originally Posted by xiaoni420
yeah kinda, just has a shorter cable that runs into the cockpit. im guessing you dont like it?
https://www.evolutionm.net/forums/sh...ht=install+mbc
oh ok, yeah i dont know, seems like the chord is too short to put the boost controller itself, in a good position under the hood to keep the hoses coming from the turbo and the wastegate shorter. its a pain in the @$$
i dont know if i can just detach the cable from the boost controller...anyone have any pics of there install or some more info?? someone has to have the short kit...thanks
if you look on the driver side of the floor board you will see a rubber gramet you can use this and it will come out on the inside of the driverside inter fenderwell if you have the driversoor open you will see what I am talking about. them the controller will come out by the car battety . that is what I had to do for my car.
do you have the short kit? if so, was the enough cable line to do so? and also if you do have it, where did you mount both the booost controller and the cockpit controller? thanks man
