IYO what is the BEST streetable turbo
I am looking for a turbo setup that will give me the best acceleration on the street, with close to, or slightly slower boost response. I really don't care about topend speed, as I want quickness off of the line. Could you give me/us some numbers as far as pricing, Hp and the like...............
Met a guy last night that said the exact same thing, and he has a GT35 w/NOS.
He said the 3076r pulls like mad! How much cash for the kit, and what kind of numbers? Hp, 1/4 mile time, Trap time etc.........
It depends on what you you consider is streetable. There are also many different variables and setups for specific turbos that would make any turbo streetable. You can make a GT40R streetable with the right supporting mods. You can also make the stock turbo superior to slightly larger turbos with the right combination of mods and tuning...
So what are your power goals and intentions with the car?
The tuning plays a big part as well, you can have a smaller turbo, with crappy tuning and it will spool slow or you can have a big turbo with good tuning and it will spool pretty quickly. I have a Precision SC61 turbo. T04E compressor cover, 56 trim compressor wheel, .63 A/R hotside with a Stage3 turbine wheel. My turbo will support up to 600hp, its non-ball bearing and I hit 20psi at 3800 RPMs. and the turbo pulls hard all the way to redline. On 93 octane and 18psi, tunes with a standalone, I made 369.9whp. That tune was extremely mild and it was done in about 45 mins. If I ran 22psi and messes with the timing, it would have made over 425whp, easy. Best of all, the turbo is affordable, its $750
check out my dyno video http://www.iamsethmo.com/Vids/stewidyno.avi
If you want the most stock-like-spooling turbo, ur gonna wanna go with a GT3071R, which spools just a few hundred RPMs later than the stock turbo. It has the potential to make about 400 whp on pump gas and around 500 whp on race gas. As far asa pricing, im only aware of one reallt high quality kit, and thats the AMS turbo kit. I think its around $4,300, which is pretty expensive, but keep in mind ur getting a really nice turbo kit.
Originally Posted by Derek888
turbo is 750 but what about the other parts thats needed to make it work?
By far the boys down in Houston @ Forced Performance have done it right with their gt3065 series turbo. I have this set up with HKS 264/272 cams and it is perfect putting 550+ hp to the ground.
my fault.
Wasn't trying to give you a hard time bro, just though I had missed something for a second there
