question on displacement and other things
Originally Posted by Shaun@SG
Hi JJ.. can't the stroker guys upshift to 5th? Or does it cost them too much time? I didn't look up the NDRA rules on transmissions, but what kind do they run? Thanks
I hope I explained that well enough to understand
Keith
Thanks JJ and Fourdoor, it is clear. It is so good that this new point could surface - given the lack of circular argument to drown it out.
I find it amazing that the NDRA / NHRA Pro classes would not have a custom gearing option, or that they even run stock transmissions? Surely they are not running H gate stockish trannys and running mid 7s? If anyone can clarify what trannys they run, I would be most grateful.
Best regards
Best regards
I am a DSM Guy and have worked on a couple blocks. Buschur being my greatest source of info and parts for my buildups. If you search his site or even talk to him he will tout the power potential of a 2.0 VS. a stroker. Above all he states the reliability of the 2.0 and its power production potential and its reving capabilities. For these reasons the motor makes higher power levels more reliably. Al Friedman from Dynoflash along with TurboTrixx states the same and run the same 2.0 displacement in terms of reliability and drag racing. Buschur also denounces the reliability of the stroker in making big power but then again he advertises and sells a stroker kit too so it is hard to judge advice form a vender.
I think it was Shaun who stated
Are the stroker drag 4G63s slower because the engine is, counter to physics, inherently less powerful?
I myself prefer a stroker and have seen what a 2.3 can do on the street, unfortunately I never have the funds to do it properly so I stuck with my stock 1G bottom end which is fairly stout to being with and just put in some 2G pistons which is more then strong enough to handle the 20G. I am not too well versed with the potential of strokers but from what I hear on the drag racing scene is that it is a negative attitude.
JJ and Fourdoor made an excellent point about the need to hold power to higher RPM given the lack of custom gearing options.
I think there first needs to be confirmation that the top teams are indeed gear limited - gear limited in terms of not having the option to gear the car right for the powerband of a 2.4. I can see some privateers running 9s and 10s being reluctant to convert to a pure race transmission, but I find it difficult to believe that the pro NDRA or NHRA guys running mid 7s would not have gearing options or that they even use a remotely stock tranny.
If, and once there is positive confirmation that they are indeed gear limited , then we can proceed to discuss the questions raised in post 87 ( https://www.evolutionm.net/forums/sh...5&postcount=87 ) . If it can be proven beyond a reasonable doubt that it is not due to those forces influencing the technical benefits of a stroker, then we can proceed to try and figure out the weaknesses in them. So far on this thread, there has been no reasonable point made against strokers except for the lack of gearing options for the stock transmission. Better yet is if someone gives us a clear and logical reason for the alleged weakness. That way we don't even have to spend too much time or effort find the weakness ourselves.
Finally, power is not purely dependent on RPM. Power is dependent on volumetric flow (density constant). Volumetric flow is dependent on valve area in combination with large displacement, or in combination with RPM. Valve area is fixed by the head. Secondary to valve area is flow efficiency. So given fixed valve area and port efficiency, there are two approaches to power - RPM or displacement. The stroker takes the displacement approach.
http://www.evoclub.net/history/evo8/swf/power_train.swf
Anyone who has spent any amount of time driving a stock Evo 7 will tell you how the car just dies after 4th cos the gearing is just too tall.
Are the stroker drag 4G63s slower because the engine is, counter to physics, inherently less powerful? OR is it because the teams that race in the most watched and contested classes (NDRA, NHRA, etc.), have the most sponsorship/advertizing money, and have the cashflow to run business, make more money off that, and then put it into development work on the 2.0s that they run? In other words, are the economic/business forces inherent in racing, and the rule structure of rule limited racing, overwhelming the advantages (that some, including I, see) in stroker 4G63s?
I have read a little of the tuner views on this issue, but there is nothing solid. Buschur criticizes the Toda kit saying it will not hold more than 7500RPM because of the stock 2.4 rods
IMHO if you wana stroker, go JUN, 2.2 and 9000 RPM’s and I believe there is an Evo making over 700WHP with it. It is a proven kit for sure and is very expensive and I think more rare for sure.
thanks for all the info guyz....specially shaun who put time and effort to share his knowledge in displacements....keep em coming tho.....this thread is not yet finished....
there is more discuss.
also i am looking into the jun 2.2 liter kit.....expensive yes!!!!!
2.0 or 2.3 for 6spd?
I am researching building a motor for my MR. I agree with the torque benefits of a 2.3L; but is the rpm capability of a 2.0L better suited for the shorter 6spd (I plan on running GT30 or GT35 turbo)? Even with a Vishnu stage 1, it seems like I'm always into the rev limiter. Thanks
Dave Burschur said stroker kits in the past have been designed with errors and that these errors have been corrected and he's waiting to see how they perform. Dynoflash Al says 2.0 is his personal preference. So let's not put our words into their mouths.
Like I said, I don't want to get into this tuner said YYYY, and that tuner said BBBB, unless the points by themselves carry weight. A discussion involving many little unexplained blurbs is quite worthless IMO. Everyone is better off using their own minds and discussing calculations, concepts, obervations, logic.
Post 87 and 95 in this thread have not been addressed.
Electric Evo.. you're welcome.
Originally Posted by dome2dome
Terry S
